Hey there,
New to the board and I have a 78 Riviera Bus and it runs like a champ other than a weird hesitation/lurch sputter, stutter something, during acceleration under load.
It is most noticeable in 2nd and 4th around 35ish and 65ish respectively.
Anyone?  Anyone?  Bueller?
Thanks for any input,
David
Wayne
Is your Bus fuel injected? Did you check the timing and make sure that the vacuum advance is working properly? Has it been recently tuned? Just a few things that come to mind...
Yeah she is fuel injected and fairly recently tuned.
I am thinking it feels like an advance thing too, but it is hard to test without it under load.
It'll get to high RPMs without a problem when it is not driving, and that is kind of the mystery to me.  I would think that you could recreate the problem without it under load, but it doesn't seem like I can.
Thanks for the notion
My 78 Westy does that on occassion and after ensuring timing is right I usually run some STP or equivalent fuel sytem cleaner through it and it is fine after that. Does it do it every time you go through the gears?
